Using FR shortcut in the INT version
I've been working with the FR since 4 years, and now I have to work with the INT version of ArchiCAD 16, and all the shortcut are different. Is there any way to use the FR shortcut in this version ?
Thank you.
1 REPLY 1
Go to the Work Environment Dialog.
Try to Export the Shortcut Schemes from the French version and import them into the English version.
There may be a few hardwired keyboard shortcuts that are localized version-specific, but most other shortcuts should switch to the ones imported from the French version.
