RDI
V12-trim to roof
I cannot get trim to roof to work in 12.
I followed the help rules, but the command is not active in the Design/Trim to roof.
I may be missing something.
RAN
Ran Wilson
8 Replies 8
Eduardo Rolon
Trim to roof does not work on sections or elevations it only works on floor plans and the 3D view.
Please DO NOT double Post.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
TomWaltz
ejrolon wrote:
Trim to roof does not work on sections or elevations it only works on floor plans and the 3D view..
Uh... yes, it does work on sections and elevations.
Tom Waltz
You have to have at least one wall selected. If no roofs are selected, then all roofs touching the wall are involved in the trim operation. If you also select some roofs, then only those roofs will affect the selected walls.
Generally, Solid Element Operations (subtract with upwards extrusion) are more productive than using the old trim to roof command. Do a search of these forums.
PS I deleted the double-post.
Eduardo Rolon
Tom,
I tried on my current file, it doesn't, the option is grayed out???
AC29 US/INT -> AC08
RDI
Thank you for the reply. I will review solid operations.
I was attempting to work in a 3D Document instead of the 3D generic perspective. It did not occur to me that it mattered.
Sorry about the double post. I consider this issue resolved.
Ran Wilson
Steve Jepson
Not in version 12.
TomWaltz
Why would trimmed roofs not work in elevations and sections? Once they're cut, they are cut in all views, not just the 3D window.
Tom Waltz
David Maudlin
Tom:
I think they are referring to the fact that the Trim to Roof... command cannot be executed in section/elevation windows.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
