Tom Krowka
VR object with photorender background
I guess the subject says it all. Is is possible to do a VR object with a photorender background. As an alternative, what does everyone use for a background that looks decent? Just a solid color wall in a circle around the VR object. That really doesn't look too good.
I'd like to use any of the backgrounds that are in the library, not an actual site pic. I can see where you would need a panorama to be accurate; that's more than I want to think about right now.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
2 Replies 2
For the VR object I just use a pale blue background to suggest sky. To get realistic clouds requires applying a panoramic texture to a big cyclorama. (Fly-throughs have the same problem)
I haven't tried this myself but I'm pretty sure others have. Dwight perhaps?
Djordje
It is very possible. If you have Art•Lantis, you also have quite a few of the panoramic bnackgrounds.
There is also an article on ArchiGuide:
http://www.graphisoft.com/support/archicad/archiguide/insertbgdpicts.html
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
