godi
Very slow paste in AC10
We have a very annoying problem with AC10 (v1010):
The paste operation last 12 to 14 seconds to finish everytime!!
It's the same in all the machines (all Mac G4, G5 an Intel). In the office we are all connected to a server, but the problem is the same in my house machine and the ibook with no net connection.
We have no problem with AC9 in the same machines.
Any solution?
Thanks in advance.
34 Replies 34
TurboGlider wrote:
..there is a layout standard that says that every pieces of a model vertical should be at the same place on a layout.
Why not set the ground floor layout as the trace reference and use that to align subsequent plans?
Because this is an AC10 thread. But should test it in next big project in AC11.
Sorry! Where is the 'slaps head and shouts DOH!' smilie when you need it?
Haneef Tayob
I know this issue was raised around AC10.
I seem to get good response times (in terms of copy-paste) by not having the [navigator-organizer] window open.
Refer to my post in 'very slow copy in AC11':
http://archicad-talk.graphisoft.com/viewtopic.php?t=21722
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
alexliz24
On a migrated project from AC10INT to AC11INT, copy is slow with complex-fill walls. For example, the same wall with a complex fill and with an empty fill takes 3 sec and 0.3 sec respectively to copy.
The .plist file is edited as per AndorSzoke's Wiki article suggestion.
Any tips?
Alex Zachopoulos
MacBook Pro 17" 2.4GHz, MacOS X 10.5.6, ArchiCAD 11 & 12, WinXP, Vista (well, not really Vista...)
alexliz wrote:
complex-fill
Please clarify: do you mean 'complex profile' or do you mean vectoral fill?
alexliz24
Sorry Karl, I did mean fill. Not Complex Profile.
Alex Zachopoulos
Haneef Tayob
godi wrote:
The same with all, no matter the size or quantity of the objets to paste.
Are you using dual monitors?
Haneef Tayob
alexliz24
I wish I did...
Alex Zachopoulos
Chris Phillips
