2015-03-14
01:10 AM
2023-05-24
08:51 AM
Rubia Torres
2015-03-14 04:08 AM
rob2218 wrote:That is sometimes just a matter of the view angle or the sun angle.
By the way Steve....do you know of a way to have two planes intersect one another "AND" show that line where the two planes intersect? I don't mean "trim" either....why is it that when two planes intersect "thru" each other...they can't seem to generate that actual line where the fold occurs?
2015-03-14 04:39 AM
rob2218 wrote:No. But it bothers me too. For example in elevation there should be an line at the intersect of the roofs even if they are not trimmed.
2015-03-14 05:52 AM
2015-03-14 09:11 PM
Erich wrote:.
Steve,
I run into this all the time and I agree, that line should not be there, but it is easy to get rid of, just pull your roof back 1/4" or so. Just enough to get the edge off the outer surface and the line goes away without the need of an SEO.
2015-03-16 07:07 PM
Steve wrote:Steve, there is another easy way of achieving this. Just go to the Floor Plan Cut Plane Settings Dialog and adjust the Offset value of the lower limit of the Floor Plan Range so that it includes the gutter vertically. Then it will appear on the upper story as well.
My problem is that my gutters are walls/complex profiles so I am having a problem finding a way to show the gutters on the first floor roofs in the same plan view as the gutters for the second floor roofs.
If I explode the gutters into morphs I can have them display on all levels.
Is there some there way to do this?
There ought to be some way to show walls and/or complex profiles on all levels.
2015-03-16 07:33 PM
laszlonagy wrote:If we could set a different cut plane for each View then that might work in some situations. I was not aware that this could be done. Othewise, no. Changing the cut plane affects too many other things like line types...Steve wrote:Steve, there is another easy way of achieving this. Just go to the Floor Plan Cut Plane Settings Dialog and adjust the Offset value of the lower limit of the Floor Plan Range so that it includes the gutter vertically. Then it will appear on the upper story as well.
2015-03-16 07:50 PM
2015-03-16 09:18 PM
2015-03-16 10:21 PM
2015-03-16 11:10 PM
