Wall Composite priorities
With v17 I can't find where to adjust the priorities like in v15 for wall leaf intersections.
In 17, composite skins join, penetrate, or block other skins based on the priorities of the Building Material of each skin... The new Building Materials attribute handles this.
A cool method of adjusting the intersections is to select a placed composite wall and then open the Building Material dialog and sort on the priority column. The materials in the selected composite will be highlighted, and you can drag them up or down in the list to change their priority relative to the other materials, visually seeing the priorities of the other skins for that composite.
It's all a radically new way of working compared to all earlier versions of AC and requires reading the various help resources, watching the videos, etc - and playing in plan and section views to really see how powerful this is. A major leap forward.
AC 29 USA and earlier   â€¢   hardware key   â€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thanks for your help Karl. Yes it's pretty cool!
I think I had better change to the v17 work environment now.
Change is as good as a holiday so here we go again!
