Wall and curtain wall display in 2D plan
Hello,
I have problem with wall display in 2d plan view. I have triangular wall (formed with solid element operations tool and morph) and I did curtain wall as well. Is there are any possibility to display wall cut and finish it in the same position curtain wall cut starts? Now I can choose between displaying wall as a cut or showing only contours.
Thank you for your answers!
3 Replies 3
David Maudlin
mariusbar:
Walls cut with SEO do not change their 2D appearance. You could split the wall where you want the 2D appearance to change at the Curtain Wall, then set each wall for the needed 2D settings.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David wrote:
mariusbar:
David
Thank you. Splitting wall is a great work around!
David Maudlin
mariusbar:
Glad that worked for you, thanks for adding the signature.
David
