Wall and door shows up in Floor Plan, Wall disappears in 3D view
bobby bent
In a two-story residential project if noticed that in a 3D view the wall is missing and the door remains.
This occurs on the first floor and the element above is a slab representing the second floor. Is this a bug in Archicad-24?? This doesn't occur in all situations. Tried deleting the slab element to see if this corrects but the error continues. Also I've noticed that sometimes when I enter a door in a wall it will appear outside the wall and it takes several attempts to align correctly while not changing the door parameters. Help!
Windows 10 (Home OS
3.4 GHz i7 Six Core
32 GB SDRAM, NVIDIA Quadro K620
ArchiCAD 24 (USA Full)
1 REPLY 1
Lingwisyer
Guru
https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=43717
