Wall/beam intersection in 3D
If we have a beam into the body of a wall when we set the beam layer off the wall is going to have a hole in the place of the beam
Is there any other way except,the "3D Intersection priorities", to avoid this?
Thanx
4 REPLIES 4
Maybe the Layer Intersection number
Scott Bulmer
See attached. Change value for layer with beam. Make sure it is a different value than the wall with the intersection.
Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
I'll try it
Djordje
Thanx
Yes.
The walls, beams and coluns have their own intersection priorities, independednt of the layers. Whoever has a greater number, cuts all else.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
