Wall below ramp and over ramp
Hi
I want to construct a wall of custom properties. Want a wall which will be below of ramp. Another wall which will be over the ramp.
How can I do this?
I m new in archicad.
3 Replies 3
furtonb
What do you mean by "custom properties"?
Maybe the solution is simple and using a solid element operation with your ramp as an operator and walls as a target ("subtraction with upwards extrusion" on the bottom wall and "subtraction with downwards extrusion" on the top wall), but I might misunderstand you.
Could you draw a sketch about what you wish to achieve and upload it?
In general there are multiple ways for almost any modelling problem to handle, based on the LOD and other factors.
odv.hu | actively using: AC27-29 INT/HUN - multiple builds | Rhino6-8 latest build | macOS @ apple silicon / win10 x64
thnx, solved
Guru
arctushar wrote:
thnx, solved
It would be great if you could explain in a bit more detail what your issue was and your resolution for anyone else who may stumble upon this thread.
Ling.
edit: follow up thread
