2006-03-29
07:01 PM
2023-05-26
03:09 PM
Rubia Torres
2006-03-29 09:52 PM
2006-03-29 09:59 PM
Mats_Knutsson wrote:If you actually want the window height to be accurate, you just turn on the "Wall Contour Line" parameter under the 2D Settings. You can pick one side, both sides, or neither.
I got stuck on a question from a customer today. They have windows that goes down to the wall and the want the wall contour lines to show in the plan. See attachment. Is this doable without 2D lines?
Mats
2006-03-30 09:51 AM
TomWaltz wrote:Well, it doesn't work when the window goes all the way down to the wall bottom. As Peter Devlin wrote I can elevate the window 1mm but I would prefer not to do that beacuse of measuring issues. Basically I understand that the plan definition that when a window goes down to the wall bottom , the wall lines shouldn't be visible because there is no wall, just a window... I will sleep on this one one for a cuople of days and maybe I will create a workaround.Mats_Knutsson wrote:If you actually want the window height to be accurate, you just turn on the "Wall Contour Line" parameter under the 2D Settings. You can pick one side, both sides, or neither.
Mats
2006-03-30 12:45 PM
Mats_Knutsson wrote:Really? It worked for me (I tested it before I recommended it)
2006-03-30 07:44 PM
2006-03-31 11:07 PM
