Wall corner challenge
I like to model a cove like this in the wall corner, tried opening tool but couldn't achieve it, I don't know it's a painting finish or special blocks stacked to produce this beauty.
If anyone knows how can this be modelled in Archicad? thanks.
AC 27 INT 5030/WIN 11
14 REPLIES 14
@Mahmoud Qenawi
Yes, the corner must be a Morph SEO-d.
This amount of grooves may not affect the performance now, but if you model them on a whole building, you will have thousands of SEOs and you can get to a point where they may.
Thank you @Laszlo Nagy ,
Yes I understand your suggestion & even it opens a new method for getting these grooves by opening tool.
I gonna try the 3 methods & evaluate results, thanks for all contributions.
Hello @Mahmoud Qenawi,
If you're still interested into the argument, there are the Youtube link of the webinar(it's in Italian and divided in three parts), there is also the presentation of the new HBIM library parts, but I think that them will be available only for Italian SSA/forward users.
https://youtu.be/pYxkYHZ91yM?si=WAP2QsiXFFR8d_rA
https://youtu.be/ALOPNv0l3A8?si=-_a3ncEsi5ieVl2-
https://youtu.be/ArBgUqpBWYY?si=Kk2uCTtrgOhFAy1m
AC 6.5-27 | Latest build | Win 10 Pro 64 | AMD TreadRipper 1950x 3.4 Ghz | 64 Gb RAM | AMD Radeon 5700 XT 8GB
Thank you so much @strangeday, you did a great job 🌺🫡.
Thanks for GS Italia for their innovative & hard work which is obvious everywhere.
Sure I’m still interested in these HBIM series, I never knew how CW tool can be a fantastic solution for this kind of historical buildings.
Can you show the Plan view of this?
I've never been successful with SEO showing up in plans correctly.
Setup info provided by author
