Zendrix
Wall end - composite wall
Hi!
This might just be a dumb question, but i have a case where i have a composite wall. I want the outter layer of the wall (made of brick/masonry) to turn and close my wall end. I would like not to just place a fill or something dumb in 2D to solve it, so what would be the best practice?
Thanks,
Z
AC28 . LeNovo Y520 Intel Core i7-7700HQ @ 2.80GHz 8GB RAM. Windows 10 Home
1 Solution
B_Migito
Hey Zendrix,
You can use this tool to get the wall end you're looking for
Go to post
3 Replies 3
B_Migito
Hey Zendrix,
Zendrix
Thanks,
I tried using it, but with no success. Gonna have a better look into it.
Z
Guru
The issue with the Wall End Tool is that it does not extend the skins past the end of the reference line, so at a corner the skins will be misaligned. Every time I use it with blade walls I have to extend the wall by the skin thickness... This sometimes works with corners.
Ling.
