‎2014-05-14
08:21 PM
‎2023-05-24
09:00 AM
Rubia Torres
‎2014-05-14 10:36 PM
‎2014-05-14 10:52 PM
‎2014-05-15 04:07 AM
Steve wrote:Always use layer combinations.
doing a search to see if I can find out how to make the group intersect number quit changing I see that this was a problem for me 7 year ago... and it still is.![]()
http://archicad-talk.graphisoft.com/viewtopic.php?printertopic=1&t=18142&postdays=0&postorder=asc&st...
There is no way to make those group intersect numbers quit changing. They are meant to be temporary.
However, apparently you can save them if you save a view that has them the way you want them.
I am don't like that at all. I want these group intersect numbers to stay the way I set them until I decide to change them again.
‎2014-05-15 10:04 AM
‎2014-05-15 01:29 PM
Steve wrote:I use layer intersect numbers to control SEO issues (I have always used slabs for SEOs and with PBCs they need a different number), control Overhead Items in plan and to be able to control and fine tune Renovation filter problems. In all cases being able to specify different layer combinations have saved me lots of time.
If the graphic anomaly is corrected by assigning different intersect numbers to the layers until you see it the way it should be, why would you want to use different intersect numbers in some other views ?
Shouldn't the same set of layer intersect numbers that worked for one Layer Combo work for all the other Layer Combos too?
another Moderator
‎2014-05-15 03:27 PM
‎2014-05-15 03:35 PM
‎2014-05-15 04:15 PM
‎2014-05-15 04:24 PM
