Wall intersection visibility
drh64
How do I get my interior wall intersections to clean up when the walls are turned off?
See the attached images
Thanks
Eduardo Rolon
Assign a different intersection number to the layer that has the interior walls in the layer set in which that layer is off.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
drh64
way too easy!
thank you!!!
