Wall joints
Hello, I am a very new user of AC START 2012 and can not have three walls joined without a vertical separation line between two of them. The first two walls form a corner and the third, of different height and thickness, starts from the corner and extends one of the higher walls. This last joint is always separated by line. Have similar problem when beam starts in corner of two walls. Wall/beam finishes are same. Am I missing something? Please help.
7 REPLIES 7
Joining walls can be a bit complex. A screen shot would help understand your specific issue.
Okay, to make it simple I made a small example. Shall I make a screen shot of plan view also?
Here is plan view:
This post on James Murrays Onland site may help -
http://www.onland.info/archives/2010/07/fixing_wall_corners_with_columns.php
Thank you. I will try it as soon as I am back in my office.
Thank you, it works great, it would take some time to figure it out without help.
owen
Welcome to ArchiCAD
You will get used to frustrating workaround for basic drafting bugs in the software such as this soon enough. This particular bug has been around so long I think it now has been listed as a heritage item (i.e never to be removed)
cheers,
os
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
