Wall on angle?
Is it possible to design a wall on angle [not perpendicular to the ground] and still be able to insert windows/doors etc...
..I can do it with a roof tool but then I can not insert openings...
that is all...
thanx
Andronikos
10 REPLIES 10
Dave Jochum
Yes. Go to Extras/Accessories/Wall Accessories, then choose "Canted Wall". Refer to User Guide Vol. 2, Pg. 159-161.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.3•AC 28 Silicon (latest build)
Djordje
Quite so. ANother (not free!) option is ArchiWall, where the cross section of your needed wall can be almost anything.
The thrid option, plain ArchiCAD (no APIs and extensions) is to make the wall as thick as its horizontal projection, and slice off the top and the bottom with the roof planes, or, if you are on ArchiCAD 8.x, using SEO.
HTH,
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I am using AC8.0 ...what do you mean by using SEO??
...david I used the wall accessories that you mentioned but I can not change the dimensions of it...and I do not think that I can insert openings..
thanx,
Andronikos
P.S. Also I do not have the user manual with me ... from where I can download it? I tryied graphisoft.com but I could not find it...
One final - general question: why archicad does not have a 3d rotation as an option... it will make our lifes a lot easier sometimes...
TomWaltz
Who makes Archiwall? I couldn't find it on Objects Online.
Tom Waltz
David Larrew
Cigraph makes ArchiWall check it out at:
http://www.cigraph.it/cigraphint/FMPro?-db=prodottiint.fp5&-format=scheda%20prod.htm&-lay=tutto&-sortfield=nome%20prodotto&-sortfield=versione&-sortorder=descend&-recid=29&-findall=
SEO stands for "Solid Element Operations" it should be located on your "Edit" pull-down menu. It is basically Boolean commands.
The user manual can be accessed from "ArchiCAD Help" on you "Help" pull-down menu.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Djordje
Insert the openings in the wall, and the accessory will adjust itself
You have it online at http://download.graphisoft.com/ftp/publishing/ac_help/
You mean rotation around the X or Y axis? You can do it, with ArchiForma objects. For usual objects, there is usually a parameter for that.
Djordje
HP Omen
sorry for asking again but...
First of all let's say that I do not want any openings - only e.g. a 10m length wall with 3m height and 10 degrees angle...,I am trying to remove the 2 defaults openings (door + window) but no luck...I do not know how..?
Secondly when I am trying to insert a window, nothing is happening... What exactly I am doing wrong?
thanx in advance,
Andronikos
David Larrew
What you are probably doing is trying to place the Wall Accessory Object manually... Don't.
What you need to do is select a previously placed Wall, activate the Wall Accessories API from the "Extras\Accessories\Wall Accessories..." pull-down menu.
The API links the Wall Accessory Object to the Wall and any Openings in the Wall will be accounted for in the Object.
AC 5.1-25 USA
David!!!: THANX!
