2004-01-27 05:06 AM - last edited on 2023-05-23 03:44 PM by Rubia Torres
2004-01-27 05:48 AM
andronikos916 wrote:Yes. Go to Extras/Accessories/Wall Accessories, then choose "Canted Wall". Refer to User Guide Vol. 2, Pg. 159-161.
Is it possible to design a wall on angle [not perpendicular to the ground] and still be able to insert windows/doors etc...
2004-01-27 06:22 AM
Dave wrote:Quite so. ANother (not free!) option is ArchiWall, where the cross section of your needed wall can be almost anything.andronikos916 wrote:Yes. Go to Extras/Accessories/Wall Accessories, then choose "Canted Wall". Refer to User Guide Vol. 2, Pg. 159-161.
2004-01-27 10:25 AM
2004-01-27 02:48 PM
2004-01-27 06:45 PM
2004-01-27 07:10 PM
andronikos916 wrote:Solid Element Operations
I am using AC8.0 ...what do you mean by using SEO??
andronikos916 wrote:Insert the openings in the wall, and the accessory will adjust itself
...david I used the wall accessories that you mentioned but I can not change the dimensions of it...and I do not think that I can insert openings..
andronikos916 wrote:You have it online at http://download.graphisoft.com/ftp/publishing/ac_help/
P.S. Also I do not have the user manual with me ... from where I can download it? I tryied graphisoft.com but I could not find it...
andronikos916 wrote:You mean rotation around the X or Y axis? You can do it, with ArchiForma objects. For usual objects, there is usually a parameter for that.
One final - general question: why archicad does not have a 3d rotation as an option... it will make our lifes a lot easier sometimes...
2004-01-28 01:34 AM
2004-01-28 08:11 PM
2004-01-29 12:15 AM
