2014-08-06
04:33 PM
2023-05-24
08:57 AM
Rubia Torres
2014-08-07 02:44 AM
2014-08-07 08:50 AM
2014-08-07 09:26 AM
Anestis wrote:And for those playing along at home the "not the same way" is to cut a hole in you morph the same size as the door or window that you want to put in.
I agree with Nando, keep in mind though that if you turn your wall into morph,
you cannot add windows / doors anymore, at least not with the same way that you would and you cannot go back from morph to wall.
2014-08-07 09:48 AM
2014-08-07 10:10 AM
2014-08-07 10:37 AM
2014-08-07 10:58 AM
Anestis wrote:Sure you can use the wall for an SEO but that would depend on what you have done to the morph.
Why cut the hole first and then add the wall?wouldn't it work if the wall was the actual boolean operator on the morph's SEO?so you can move the window/door and the hole at the same time.
2014-08-07 07:25 PM
2014-08-08 09:04 AM
