Wall slant
I would like to taper a curved wall from top to bottom in Archicad 15. This would be similar to an inverted cone surface unwraped to an arc. Thanks.
6 REPLIES 6
Dwight
Without being a workaround apologist or anything, for now, use a curved ramp to trim the wall with a Solid Element Operation.
Dwight Atkinson
Thanks for the info. I didn't explain myself very well. I would like to taper the sides of a wall. Not the top like a ramp. The top of the wall would be the original width and the bottom of the wall would taper inwards creating a narrower footprint than the original. I'll try to use a roof element on each side and trim to the bottom and see if that works. Thanks again.
Eduardo Rolon
Is this what you are looking for?
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Eduardo Rolon
Curve example 01
AC28 US/INT -> AC08
another Moderator
Eduardo Rolon
Curve example 02
AC28 US/INT -> AC08
another Moderator
Eduardo Rolon
or with a custom profile
AC28 US/INT -> AC08
another Moderator
