‎2006-10-04
09:20 AM
‎2023-05-26
03:03 PM
Rubia Torres
‎2006-10-04 09:43 AM
‎2006-10-04 03:42 PM
Barry wrote:Yes you can. THe fastest way for the mice oriented people is right click, choose "show selected/marquee in 3D"
You can't use a marquee it seems and show just that in 3D.
‎2006-10-05 04:07 AM
Djordje wrote:That's exactly what I am doing - F5 or right click and choose "show selected/marquee in 3D".Barry wrote:Yes you can. THe fastest way for the mice oriented people is right click, choose "show selected/marquee in 3D"
Or hit F5.
Reading What's new, and Help, ocassionally, also helps.
‎2006-10-05 09:17 AM
Barry wrote:Logic: A wall set as you describe it won't be visible in any plan view, will it? As I interprete it, the 'single story' marquee will only show items that are visible in the current story plan view. It is similar to selecting items in the view. To show invisible items, you need to use the fat marquee and limit it to this story using the filter options.
What they don't tell you (at least not that I saw) is that if you have the single stoey marquee then you won't see the "cut only wall if they are lower than the floor cut plane, completely in the same storey and set to show on "own storey only".
But as I just discovered if you use the all storey (fat) marquee then you will see these walls.
Why the single storey doesn't work is any one's guess. Barry.
‎2006-10-06 04:49 AM
Thomas wrote:There is some logic there in that respect if I was to select items.Barry wrote:Logic: A wall set as you describe it won't be visible in any plan view, will it? As I interprete it, the 'single story' marquee will only show items that are visible in the current story plan view. It is similar to selecting items in the view. To show invisible items, you need to use the fat marquee and limit it to this story using the filter options.
‎2006-10-06 12:44 PM
Barry wrote:Well ... now you started Ben, I am sure - this is called consistency, the Graphisoft way. Thin marquee is for the elements on a certain storey, thick for all stories, right? Right. Now then - the walls transcending stories, are not EXACTLY on a certain storey, therefore they don't show ...
