Eman
Walls - Different Colors
If I have 4 walls in 2D with yellow colors and I want to change one to black color as the image, what is the proper way to do it?
https://yadi.sk/i/tjc38lmlHNaWeQ
Thanks
Eman / Draftsman
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz, 8.00 GB, 64-bit operating system, x64-based processor
1 Solution
Walls can not change colour (appearance) along their length, unless there is an opening object (door or window) placed in them.
Or they are interacting (trimming) with walls in another layer.
Otherwise they must be separate walls.
Also if a wall has its 'Floor Plan Display' set to 'Projected with Overhead' then the height of the wall in relation to the Floor Plan Cutting Plane will come into effect.
Depending on your wall settings generally a wall below the FPCP will be solid line with empty fill.
A wall being cut by the FPCP will appear solid.
A wall above the FPCP will appear dashed line and empty fill.
Go to post
6 Replies 6
Eman
Ok maybe I did not make myself clear enough. What I mean is how can I make walls with different colors as the image?
https://yadi.sk/i/Ff0mkYfI2YEWjg
Thanks
Eman / Draftsman
Lingwisyer
Guru
Use a building material that has a different cut fill between the two that you want?
Ling
Eman
Ling
Hi Ling and thanks for your reply.
I already tried that way but I think there is another option. In the image there are walls that a wall in itself has 2 colors (brown and white).
With building material I cannot do that.
Eman / Draftsman
Lingwisyer
Guru
Are those walls on different stories? If so, are you overlaying views? In which case you could just use a different GO.
Ling.
Eman
Hi Barry and thanks for your reply
Eman / Draftsman
