‎2007-11-13 08:54 AM
‎2007-11-13 09:33 AM
‎2007-11-13 12:41 PM
Remy wrote:Also remember that they are set by Layer Combination too, so update those as well.
Try setting one of the walls on an other layer with an other number i.e. 2 instead of 1. (to the right of the wireframe/solid option. in the layersettings that is)
‎2007-11-14 12:47 AM
‎2007-11-14 03:13 AM
‎2007-11-14 06:51 AM
‎2007-11-14 07:22 AM
Ranga wrote:As Remy and Max suggested, set your layer intersection priority numbers to be a different value for each layer.
sorry
if we place the two wall in two different layers also blending the walls. But, if we make the first wall layer invisible and lock the layer then we draw the wall in other layer it is not blending.
Is there any chance can i get this effect with out invisible and lock the layer?
ranga
‎2007-11-14 07:48 AM
‎2007-11-14 12:28 PM
