2003-12-01
06:52 PM
2023-05-26
12:55 PM
Rubia Torres
2003-12-01 07:17 PM
2003-12-02 06:29 AM
Dave wrote:What are the column and wall core fill materials? If they are the same, they will melt together. If not, the wrapping can be a problem.
It seems I can't get a wall to wrap a column if the wall has more than one skin other than the core. The manual clearly shows wrapping with multiple skins.
2003-12-02 07:29 AM
2003-12-02 01:06 PM
Dave wrote:Could you send a screen shot of what exactly happens, and what would you LIKE to happen?
Cores are the same. In every case, I can only get the skins to wrap if there is one wrapping skin plus the core. With two or more skins, they won't wrap.
2003-12-02 05:16 PM
Djordje wrote:Here is what happens with the 2-skin composite wall I want to use. The outer skin is stucco, the inner skin plywood/bldg. paper, the core wd. framing. The column has a plywd./bldg. paper skin with wd. frmg. core. (Sorry, the fills look horrible in this jpeg, but I think you can see what's going on.) "Like" shot to follow.
2003-12-02 05:20 PM
2003-12-07 01:47 AM
2003-12-07 05:04 PM
Dave wrote:Dave,
I'm having trouble understanding when walls will wrap columns and when they will not. I've placed a column "by the book", i.e., composite wall w/ wrapping skins, chose wrapping before placing column, column touches wall core. While I can get many instances to work, others will not. Without going into more detail, is there something I should be taking into consideration that I haven't mentioned?
2003-12-07 06:02 PM
