2013-09-20 02:19 PM - last edited on 2023-05-24 09:09 AM by Rubia Torres
2020-09-09 02:47 PM
2020-09-09 07:56 PM
mnguyen wrote:Thank you everyone for your responses! Mlnh, when I deleted the window, the wall showed back up. I tried the same thing with another disappearing wall, this time with a door (same complex wall profile), and it worked as well- the wall showed up when I deleted the door. I have about a half dozen disappearing walls in this project. Many of the walls with the same profile and window work fine for some reason. They all have Cad Image doors/ windows. How can we fix the issue? Do you need a file as Barry suggested? Barry, thanks for the forgiveness btw
Hi Luke,
Thank you for the report and I am sorry about the issue!
I have come across this issue once, where the window was the one making the wall disappear. But in that case, the wall stood alone, no connection was made to any neighboring wall. Could you try to delete the window and see if it brings back the wall when the wall is connected properly?
Thank you very much!
Best regards,
MInh
2020-09-10 03:17 AM
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2020-09-11 07:56 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
