Walls don' t join at all
Hey. I have a problem will wall intersection. They connect only in the centre and the rest looks like in the picture. Althought it' s only visible when I select them. It' not the case of material because they are the same. I've tried everything to connect them. Please help me.
7 REPLIES 7
Eduardo Rolon
Try this:
1. Select both walls
2. Go Edit->Reshape->Intersect
3. Pan or zoom out a little to force refresh
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
fuzzytnth3
Just checking you have got the "Clean Wall" button activated?
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
ejrolon wrote:
Try this:
I' ve tried and it stays the same.
I can't find such button.
Eduardo Rolon
Under the View Menu -> On Screen View Options -> Clean Wall Intersections
Presuming that both walls are in the same layer…
AC27 US/INT -> AC08
another Moderator
Ok, I know what was wrong. I had to switch it on.
fuzzytnth3
In my Work Environment I have the "On Screen View Options" toolbar displayed which you can do as shown in the screenshot below.
This toolbar give access to a lot of useful settings
