Walls don' t join at all
Hey. I have a problem will wall intersection. They connect only in the centre and the rest looks like in the picture. Althought it' s only visible when I select them. It' not the case of material because they are the same. I've tried everything to connect them. Please help me.
7 Replies 7
Eduardo Rolon
Try this:
1. Select both walls
2. Go Edit->Reshape->Intersect
3. Pan or zoom out a little to force refresh
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
fuzzytnth3
Just checking you have got the "Clean Wall" button activated?
Using AC25 5005 UKI FULL
ejrolon wrote:
Try this:
I' ve tried and it stays the same.
I can't find such button.
Eduardo Rolon
Under the View Menu -> On Screen View Options -> Clean Wall Intersections
Presuming that both walls are in the same layer…
AC29 US/INT -> AC08
another Moderator
Ok, I know what was wrong. I had to switch it on.
fuzzytnth3
In my Work Environment I have the "On Screen View Options" toolbar displayed which you can do as shown in the screenshot below.
This toolbar give access to a lot of useful settings
