Wayne
Walls external
I am missing the "Walls external" tool layer.
I am very new to Archicad. Please can someone tell me where to find this?
2 Solutions
Rajesh Patil
Layers are user defined elements, anything designed in the template will get automatically generated in the new project that you create. Use the Layer Dialog from the Pull Down menu > Document> layers > Layers (Model View) or use Ctrl + L in window based Archicad.
From the layer dialog use "New" layer button on right side top. Later use the same for drafting.
If willing to learn Archicad from basic follow my you tube channel.
Rajesh Patil
AC 09-27 | INT | WIN11 64
Dell Inspiron 7591, Core i9, 9880H 2.30GHz, 16.0GB, NVidia GeForce GTX1650, 4.0GB, SSD Internal 500GB, Dell SSD External 250GB
Go to post
Steve Jepson
Why do you not want to just create a new layer called "  Des: Walls. Exterior "  or something?
When you add a period in the Layer name you have a layer name Extension.  That can be helpful for all sorts of things.
Go to post
5 Replies 5
Rajesh Patil
Rajesh Patil
Wayne
Thanks so much. I will go and look at your channel.
Steve Jepson
Steve Jepson
Look at my channel?  I didn't know I had one.  What are you talking about?  I would love to see it 🙂
Wayne
Careful inspection will show that I was responding to Rajesh. 🤣
