License outage
Dear Customers, We are facing with an outage in our services in Azure. You may experience issues with the Azure-based functions, like licensing, BIMcloud SaaS, Learn Portal. We are working hard on this issue to make it fixed as soon as possible. Thank you for your patience.
Using the same fill you can use 2 different pen sets for the drawings. One for the floor plan were the fill pens are grey and one for the sections were the same pens are white.
Eduardo Rolón AIA NCARB AC27 US/INT -> AC08
Macbook Pro M1 Max 64GB ram, OS X 10.XX latest another Moderator
You can also use "Uniform pens for cut elements" in Section settings and show your fills as white, or use Model View Options to set different display options.
