Walls fills different for plans / sections
I was wanting to know if there was a way to have black solid fill walls in plans but have the walls show as a blank fill in section?
Thanks
2 Replies 2
Eduardo Rolon
Using the same fill you can use 2 different pen sets for the drawings. One for the floor plan were the fill pens are grey and one for the sections were the same pens are white.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
You can also use "Uniform pens for cut elements" in Section settings and show your fills as white, or use Model View Options to set different display options.
