2020-01-16 11:25 AM - last edited on 2023-05-09 04:17 PM by Rubia Torres
Solved! Go to Solution.
2020-01-16 04:09 PM
2020-01-16 04:09 PM
2020-01-16 07:27 PM
mbl wrote:Thank you, mbl, your response makes complete sense.
Cut Fills exported from Archicad (for example from Walls in Plan) are not exported as one, but as series of smaller "fills" in form of triangles or rectangles (if you use Composites).
The line you see in PDF is just the way your PDF viewer is displaying edges between those fills. It's just a display thing, so the "line" is not visible when you print it.
But if you want to get rid of it anyway, you can do the following in Acrobar Reader: Edit>Preferences>Page Display>and make sure "Smoth Line Art" is not checked.
