Weatherboards/Wall covering isn't connecting.
I'm fairly new to this program and I'm wondering why my wall coverings isn't connecting together. My north wall covering connects well with my east and west wall coverings, but my south wall seems to not connect with them.
3 Replies 3
https://imgur.com/a/ZT3g143 For some reason images isn't popping up, but here is a link to both of them. Thanks
Lingwisyer
Guru
How have you made that?
If it is with a Complex Profile Wall, it might be due to your Wall Leaf having a higher IP than your Weatherboards in conjunction with some undesired junction connection. In that case you will just need to check your junction for tails.
Nothing else comes to mind at the moment...
Ling.
It appears to me that it is done with the wall accessory add-on.
It looks like it is not allowing for the corner trimming of the wall.
What accessory object are you using?
