What is the difference between 2 doors if only reveals are different ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2022-02-21 07:29 PM
Hi , I read the manual about "reveal", but still can't understand what is the difference when reveals are at opposite sides but doors are same shape and located similarly,
like on picture.
P.S sorry for placing 2 questions in short time, that one is last, thanks for help.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-02-21 08:04 PM
Hello kosta,
On closer inspection, it seems that the two doors are placed differently inside/outside but they both open on the same side.
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello kosta,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-02-22 02:12 AM
The 'reveal' side is the side you first click on the wall to place a door window.
You will see the 'sun' symbol.
When you adjust the reveal offset, it will move the frame forwards/backwards in relation to this reveal side.
0 (zero) offset - the frame will be flush with the wall on the reveal side.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-02-22 08:32 AM
Most likely I didn't notice anything because I'm having a frame at the center of a wall thickness, so it really only affects the frame allocation ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-02-22 09:02 AM
Yes it is basically the frame reference point.
If the frame equals the wall thickness, you will not notice any difference.
Unless you have some feature like an external brick sill or shutters - something on one side of the frame but not the other.
This reveal side will affect which side those features show on.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-02-22 09:07 AM
Ok so basically sun icon means outside, Thank you for help.
I don't want to crete new topic for that one but dont think it is something that is easy to do because once I saw similar topic, in short:
How to create custom door ? like this one below
as you can see it has a opening at right side and 2 frame divisions on the left, Can I easily edit or create any custom door layout? maybe just to rearrange existing elements and not create totally from scratch.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-02-22 12:33 PM
Now you are getting into a new topic - custom doors and windows.
Best to start a new post so as not to get lost in this one.
I can give you some info in the new post when you create it.
