When I turn off the inner boundary line to turn the finish wall inside, a line like that comes out?
LeeJaeYoung
can you erase it?
AC27 on window 11
Laurentiu
You can, just untick this and only one single line should be displayed.
Laurentiu Cauni | Architect | AC 17-28 INT
Windows for AC & iOS for BIMx
Laurentiu
LeeJaeYoung
I thought it was the same concept as this, but it's a different concept. Thank you. ^^
AC27 on window 11
