Yes, I have them all turned on. I see
show wall hole hp
show unit hp
show reveal hs
show egress hs
show leaf hs
But none of these will get me what I want. I used to be able to set a clearance hp on the pull side. SO when I placed a door and then the wall moved (that it was opening up against) I could use the hotspot to move the door so the frame was 2" away from the wall. It was very convenient.
Do I set one of the above hotspots. None of them really seemed correct to me.
And While I have you listening to me
... how come there are so many door objects. Once I set up a door with the frame sizes, fill types, maker specifications, etc...... etc.......... , etc.... and then I want to add a sidelite and the door I started with doesn't have a sidelite option I have to redo absolutely everything! It takes a lot of time to reset up all those things when it could have already been done.
Thanks,
Michele
