LeeJaeYoung
Why is it combined in 3D but not in 2D?
AC27 on window 11
1 Solution
ESK
This question is properly answered in beginner Graphisoft's Youtube tutorials.
The (blue) references lines have to meet in order for the walls to merge. The walls building materials defines which walls will merge.
I will recommend using a Graphic Override for your plan drawings to achieve the precise appearance.
Windows 11, Intel Xeon W-2125 CPU @ 4.00GHz (4 cores 8 threads), NVIDIA Quadro RTX 4000, 64 GB RAM 2666MHz, 1 TB SSD.
Archicad 17-27
Go to post
5 Replies 5
ESK
Archicad 17-27
LeeJaeYoung
AC27 on window 11
LeeJaeYoung
What you're saying is connect it like this and drop it down into Display order?
AC27 on window 11
That is what I would do.
This is awkward as the walls do not meet at an exact corner.
The thin wall overlaps a bit and send it backwards in plan.
3D should be good.
LeeJaeYoung
This phenomenon appears on floor plans viewed from four or more floors above.
The strange thing is that it produces results like this later: ^^
But this doesn't seem to be the answer.
So I gave up and replaced it with the same polyline wall.
AC27 on window 11
