Window Door Schedule
Noel Gardner
Element ID , plan view, elevation, width, height etc won't show up in my schedules
even though they are selected in scheme settings.
20 REPLIES 20
Yes that is it. Image is what I normally achieve.
Noel Gardner
I think image didn't attach before. This is my normal window scheme.
My settings look the same to the one that won't show elevations ID etc like this.
ryejuan
i'm a bit lost now from your 1st post leading up to your recent post. ðŸ˜…
i saw in your screenshots you manage to get the scheme working...
not that clear what we are trying to resolve. ðŸ¤”
WINDOWS 11 PRO
That schedule I shared was from another drawing. What I am trying to achieve is for the blank looking scheme to look like the image I just shared,
This is what my window schedule looks like on the drawing plans I am wanting help with. This is a different drawing to the correct window schedule on another drawing . As you can see the views the ID the height will not show up.I have no idea why . Both drawings look like they have the same settings.
My element types are identical to  the schedule that works correctly.
maybe can try importing this in your window schedule scheme.
WINDOWS 11 PRO
In the Project where the schedule does not list value, it is because it did not find any elements that satisfy the criteria. Are those Windows properly classified as Windows?
Thanks Laszlo.  My windows are labelled W-01 onwards etc as per attached floor plan.
The ID's also show up on the elevations. I am able to produce Window schedules correctly on other drawings but not on this one. The doors are similarity labelled.
Are your Windows classified as Windows?
Your Schedule Criteria says:
"Archicad Classification" is in branch of "Window"
which means that your Windows must be classified as Windows to appear on the Schedule.
