2 weeks ago
I have two questions about the return on a window reveal in a composite wall. (I'm attaching a screenshot below.)
1. Can I have two composite skins return into the window reveal? I'd like my stucco (green) AND my waterproof membrane (cyan) to wrap into the opening. (I have a workaround for how I'd actually construct this, but it will be a pain to model!)
2. I've got the composite skin ends turned on so that everything joins up properly, but that means it gives me a little "tail" where the stucco returns into the window reveal. Any way to turn off that little green nub??
Hopefully you folks have an easy answer!!
Solved! Go to Solution.
2 weeks ago
- last edited
2 weeks ago
Have you tried fiddling around with the settings for the wall closure ->
If I understood your question correctly, you can achieve your desired turn-in by adjusting those parameters.
2 weeks ago
- last edited
2 weeks ago
2 weeks ago
Ok yes thank you. I didn't realize it was a two-step process....select the skin from that drop down and then adjust its parameters separately. Got it. Thank you!
(Any ideas about changing that skin end line though??)
