Festim Idrizi
Window Round Reveal
Dear Friends,
Hope you are doing well.
I have a problem that I can't find a way to do it.
Has anyone done a round revealer and does anyone have an idea how to do it?
Best!
1 Solution
DGSketcher
Legend
I'm sure there are lots of alternatives. Here's another one. Set the wall hole wider than the window and place a column with the correct reveal assembly in the space at the side of the window.
Go to post
5 Replies 5
runxel
The easiest way would be to use a big reveal, and then in this reveal you put a shell with this rounded form.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
DGSketcher
Legend
Festim Idrizi
Thank you, I already did it with a column. Do you think the shell is better than the column?
Festim Idrizi
I already did that, the only thing was that I wanted to be connected with the window.
Anyway, thanks for the solution.
runxel
You don't need three elements but one. For me thats a plus.
But scratch the shell for this particular usage. I only used it before to have a revolving thing around my windows. It will be boxy tho, not rounded.
So for your particular case the column technique is better.
