Window label in elevations ArchiCAD 20 problem
Hi, I have been using archicad 18 before, labeling windows automatically was easy with one click on label window command in window properties... this option is missing in AC20, how should I do the same now?
Entire listing and labeling tab is misssing...
Thanks
4 Replies 4
David Maudlin
merloozo:
This option was dropped when the ability to have multiple Labels attached to one element was introduced. There is the new command Label Selected Elements that replaces the checkbox. If you imported your old Work Environment then you will need to add this command.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
where can i find more about how to use it?
Its use is quite simple, see this clip:
https://www.youtube.com/watch?v=HHX6iCIVmO0
David Maudlin
Or in the Help files see: Documentation > Annotation > Labels.
David
