4 weeks ago - last edited 4 weeks ago
Hi
What is the right solution for making such intersection with the drywall, going into the window opening, closing on the windowframe?
Thank you
Solved! Go to Solution.
4 weeks ago
If you extend the interior wall past the Reference line of your exterior wall.
You should be able to use the Split Tool, and trim it to the backside of your window frame
4 weeks ago
