2007-05-25
03:38 AM
2023-05-25
06:14 PM
Rubia Torres
2007-05-25 04:42 AM
2007-05-25 08:24 AM
2007-05-25 04:07 PM
2007-05-25 05:32 PM
Olivia wrote:If it is an Emply opening, the sill pen is the "Symbol Pen" within the Parameters panel. The end lines of the wall "inherit" the cut pen of the wall.
Thanks,
I gave it a go, but when I do that the sill in the distance thickens as well. Is there a way to define a thickness for the sill in the distance, and also a line thickness for the wall ends>
2007-05-28 02:46 AM
2007-05-28 07:35 PM
Olivia wrote:Where do you have this set? Within the "Floor Plan and Section" Panel, under "Cut Surfaces"?
I have my wall cut line pen set at .35mm
