Hello all,
I have a W Direct Glazed window and I would like to know what some of the settings are for:
Under "Parameters>Options" I see a setting called "Align to Door/Window on Side" from the description I can just about figure out what this does. My question is what does this actually do to the window. I have checked this off and I see nothing happening to the window in the preview box. If I knew what it was doing I could work with it properly. The same goes for the "Lining" description. Do these have anything to do with mulling windows together, if so that would be great!
See attached
Robert J. Garand
ArchiCAD USA 28-Build 3110 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
