Window sizes / dimenions
Hi all.
I have recently upgraded from AC 7 to AC 11 (so as you can imagine I've missed out on quite a lot of new features.) I'm loving AC 11 in comparison, but I call AC 7 'ol reliable because it wasn't overly complicated and mine ran virtually bug free.
I've worked through most of the new features in AC 11 but I am stuck with one annoying little thing. In AC7 you could turn off the window dimension text quite simply (see attached image)
Where do I do the same function in AC11 ?
5 Replies 5
Rod Jurich
moloneyds wrote:
/......Where do I do the same function in AC11 ?
Look in your Info box.
Expand it to see all. And check your WE to see it is checked to be seen.
Rod Jurich
Rakela Raul
wHAT about speed? any difference ?
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Thankyou Rod ... very helpful
Hi Rakela, Yeah there is no question that it uses up more resources and is a little chuggier, need a video card upgrade !
It is better to use this:
Document/Set Model View/Model View Options...
In this way you do not have to select all the windows and doors to remove the dim. marker.
Great tip kliment ... thanks !
