Window sizes / dimenions
Hi all.
I have recently upgraded from AC 7 to AC 11 (so as you can imagine I've missed out on quite a lot of new features.) I'm loving AC 11 in comparison, but I call AC 7 'ol reliable because it wasn't overly complicated and mine ran virtually bug free.
I've worked through most of the new features in AC 11 but I am stuck with one annoying little thing. In AC7 you could turn off the window dimension text quite simply (see attached image)
Where do I do the same function in AC11 ?
5 REPLIES 5
Rod Jurich
moloneyds wrote:
/......Where do I do the same function in AC11 ?
Look in your Info box.
Expand it to see all. And check your WE to see it is checked to be seen.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Rakela Raul
wHAT about speed? any difference ?
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Thankyou Rod ... very helpful
Hi Rakela, Yeah there is no question that it uses up more resources and is a little chuggier, need a video card upgrade !
It is better to use this:
Document/Set Model View/Model View Options...
In this way you do not have to select all the windows and doors to remove the dim. marker.
Great tip kliment ... thanks !
