Window
Hi Barry,
Could you please help me how to create this window? I've been trying to find the similar window and then manipulate it but not found anything. Thanks
2 ACCEPTED SOLUTIONS
Lingwisyer
Guru
You should add a signature to your profile as Windows and Doors are one of the many things which are AC version / library specific. See mine for more information.
Ling.
ps. People should stop asking for Barry. This is a user community forum, not an "Ask Barry" site.
No need to address me personally.
I know I answer a lot of posts, but I am not necessarily the best person to answer. 😮
In this case I am not, as I don't use the default Archicad library, so I am not familiar with the Graphisoft windows.
You seem to be from Australia, so you should have this window in your default Archicad library.
Other nationalities may not have it.
That will give you the basic set-up, but you will have to explore the other settings for frame sizes, etc.
Lingwisyer
Guru
Ling.
