ā2006-06-09
02:06 PM
ā2023-05-26
12:36 PM
Rubia Torres
ā2006-06-09 02:14 PM
g.h.design wrote:hi greg
Does anyone know of a way to be able to toggle a selected item's layer from solid to wireframe?
ā2006-06-09 02:46 PM
ā2006-06-09 04:41 PM
ā2006-06-09 04:48 PM
g.h.design wrote:Sounds like a good candidate for the wish list. Either as a contextual menu item like Hide Layer & Lock Layer, as part of the quick layers palette, or both.
Thanks for the response,
but I think my question needs to be a bit clearer. I was hoping that there is a way toavoidgoing to the layer's setting dialog.
I want to be able to select an element in the 3D window and toggle it's layer's wireframe / solid setting with a keyboard stroke on the fly so that I never have to leave the window to go to dialog box...
Just a little thing that would make my 3D work flow a bit better and inspire me to go to wireframe more often. I thought if there is a keyboard shortcut in that long list that I have missed it would be great to find it...
Thanks
ā2006-06-10 12:49 PM
g.h.design wrote:ah! sorry for the misunderstanding! that would indeed be a great usability feature . . . have you put it into the wishlist?
ā2006-06-10 05:25 PM
ā2006-06-10 11:59 PM
g.h.design wrote:I think a contextual menu item would be more like it. In either case this is something for the wish list as it is not possible now. It is a very good idea though, and shouldn't be too tough for GS to implement.
This would be very helpful when working in 3D. I would like to be able to select a wall for instance and turn it to wireframe while I move a beam or header in the wall, then turn the wall's layer back to solid again. If I could do this with one click it would be extraordinary.
A keyboard shortcut so that I don't have to open the layer's dialog box...
Thanks
