Wireframe vs Shading
Somehow even though I set the file to Shading, save the file, close, (or completely close and restart AC). When I reopen the file it's back to wireframe!
Has happened to other files occasionally but not as often as this one.
Likely causes??
vistasp
Hi Lec,
Is this a generic perspective/axo or is it a saved view?
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Hi Vistasp
Hope your doing well.
Thanks for the reply.
It's generic I believe, but I'll take another look latter on (off to a job site right now) to see if I can define when it happens, and when it doesn't and post back.
Take care.
Have a great day.
Be safe out there.
lec
You may want to check the layers of those elements are not set to wireframe mode.
