‎2012-12-12
01:56 PM
‎2023-05-25
05:42 PM
Rubia Torres
‎2012-12-12 04:18 PM
‎2012-12-12 04:22 PM
‎2012-12-12 04:24 PM
JaredBanks wrote:Jared, that's right. You are the man!
If you set the slab to a composite structure (which has a specified thickness) instead of a generic fill, then the (b) will be grayed out. Any changes to the (t) will result in the entire slab raising or lowering.
‎2012-12-12 08:15 PM
‎2012-12-12 08:46 PM
s2art wrote:A Chain button would not hurt. It could give you both worlds in
I like the fact that there are two (or more) ways of adjusting elevation. If I want to move the whole thing I use the element's settings, (or Elevate tool, as Jared suggested), if I only want to adjust either the top or bottom surface I use the InfoBox. Best of both worlds.
