Learn more
maurice100
Worksheet size/ shape editing
Can anyone advise if it is possible to change the size of a worksheet? I can only move the location of the referenced area.
My work around is to pick up the parameters of the original worksheet and then to create a new one. Seems to be the case also with detail sheet references.
Archicad R27
Mac Book Pro 16" Apple Silcone
4 Replies 4
Eduardo Rolon
Try this,
1. Marker set to Follow Clipping Polygon
2. Turn On "Marker Range" in disply settings
Edit the polygon.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
maurice100
ejrolon wrote:
Try this,
Edit the polygon.
Thanks - very simple once you know how to change it.
Archicad R27
I know this is dumb but where do I turn on the marker range? This one frustrates me all the time.
Marker range in menus.
